Licencia de active presenter
Buenos días,
Tengo una tablet windows y un portatil, hay veces que trabajo en un dspositivo o en otro, quiero saber si puedo tener instalado Active Presenter en ambos dispositivos sin tener que estar quitando la licencia en uno y poniendola en el otro continuamente.
Solo se trabajaría en uno a la vez nunca en los dos simultaneamente
Gracias
Hello,
Thank you for your question.
Yes, it is possible to install ActivePresenter on both 2 devices with one license, as long as both are desktop devices (Windows/macOS). A single license allows activation on up to two desktop devices for the same user.
However, the license is intended for one user only, and it should not be used simultaneously by multiple users.
So in your case, you can install and activate ActivePresenter on both your tablet and laptop and freely switch between them for your work.
Please feel free to contact us if you have any other questions.
Best regards.
No me deja, en el equipo que lo tengo instalado, active presenter está cerrado, al meter la licencia en la tablet me dice que esta clave de producto se ha activado hasta su límite de volumen
Hello,
Thank you for your message.
Please check whether your license is a Personal License or a Company License. Only Personal Licenses can be activated on up to two computers at the same time for the same user.
If your license is a Personal License but you still cannot activate it on the second device, please send us your license key so we can check it for you.
You can also view your license information and deactivate devices at the following page:
https://atomisystems.com/activation/activepresenter/
Best regards.
Como se si mi licencia es Personal o Corporativa
Hi Francisco,
To check if your license is Personal or Business, please read the information below:
Personal License
Based on the ActivePresenter EULA, a Personal License is for individual users who purchase the software for themselves (not on behalf of a company or organization).
What you get:
  • You can install and activate it on up to 2 devices (for example, a laptop and a desktop)
  • It must be used by you only
  • You can’t use both devices at the same time
Business / Organizational License
A Business License applies if the software is purchased for a company, corporation, or any organization.
  • Each license is valid for one device at a time
  • If multiple people or machines need access, you’ll need multiple licenses
How to check your license type
Let me know if you have any more questions!
