But i’m wondering if it’s possible to use a shape (or a layer) to mask an odject (or another layer), I mean something similar to photoshop.
Let’s say i want a text to appear in the middle of my scene, i can hide it behind a rectangle filled with the same color as my background, but if my background is a gradiant, it could be very tricky to get this effect.
Is there a way to create a black/white mask (ala Photoshop) for this text, so it can only appears if it’s in the white part of the mask ? Could it be a feature request ?
I’m not sure if you’re using Saola Animate or Tumult Hype?
If you’re a Saola Animate user, you should know that there are several way to do the text mask in the latest version (2.7.1). For example, you can use Clip effect, or Overflow Hidden.
Hi. I use two software … Saola Animate I have already tried it but it has not succeeded for the group of the elements … Tumult hype if it already has content scrolling included … Very nice and very creative …
Ahhh I didn’t realize it exists there … I don’t know any English. I only write here translate from google. Of course Saola Animate does not have a Spanish language. This is why it is so much more difficult to catch software! Tumult hype already has multilanguage, like adobe Animate CC.
