Please choose an appropriate sub-category to post your question or topic.
I want to change the language of the slide text in the picture. I was able to do language customization everywhere but couldn’t find it here. can you help me? (slide 1/1)
Hi Hamdi,
We confirm it is an issue in the current version of ActivePresenter (9.0.6).
It will be fixed in the next update.
We are sorry for this inconvenience.
Regards.
Any progress on the subject?
We will try to release the update this week.
Hi all,
To ensure the quality, we extended the release schedule for further checks.
We apologize for any inconvenience caused by the delay.
All the best,
Hi @eyyup_dogan and @hamdi_goktas,
A fix for this bug is now available with the latest update that we have released.
Kindly simply go to the Help tab and click on Check Updates.
Best regards,
Thank you. @PhuongThuy_Le Problem solved.
