Problem: Justified text does not work correctly. There are some spaces at the end of every line.
It is solved configuring margins at 0 but is not perfect, however.
ActivePresenter version: 9.1.3
OS: Microsoft 10
OS: Microsoft 10
Hi @JuanD18,
Thank you for reporting this issue. Our team will thoroughly investigate the matter to determine the cause and see if it can be resolved.
Hi @JuanD18,
The latest version ActivePresenter 9.1.5 is now available with your issue fixed.
Please go to the Help tab > Check Updates.
¡¡¡Thank you, Hang!!!
