Problem: Hi, I’m working on a timeline based project with 20 labels.
I’d like to just jump to the previous and next label with just 2 buttons.
You can do it with ‘jump to previous or next scene’ but not labels.
Is there a way to do this? I’d rather make 2 buttons than 20 for
each label. Thanks!
The script sorts the label timestamps incorrectly so you see it ignores some labels.
Please search for labelTimes.sort(); (line 11) in labelNavigation function, and replace it by the following script:
labelTimes.sort(function(a, b) {
return a - b;
I’ve updated the sample in my first answer, you can also download it again.
