is it possible to use json file format in ActivePresenter for smaller illustrations? I want to have animated icons, which will only be animated when the user hovers over them. For the animated icons we use json files, which already include the animation itself. I was fiddling around with activepresenter but was not able to make the magic happen.
Otherwise (e.g. in case you want to click the animated icon to show/hide another object), you should do the following steps to embed the animated icon directly into a shape:
Add script to load Lottie library in Project > Properties > On Load event
if (!window.bodymovin) {
var lottieUrl = 'https://cdnjs.cloudflare.com/ajax/libs/bodymovin/5.11.0/lottie.min.js';
var script = document.createElement("script");
script.type = 'text/javascript';
script.src = lottieUrl;
document.head.appendChild(script);
prez.loadLottieAnimation = function(loadAnimFunc) {
if (window.bodymovin)
loadAnimFunc();
else
script.addEventListener('load', loadAnimFunc, false);
Add a shape to the slide, the lottie animation will be loaded into this shape in step 3. You can make this shape transparent by settings its fill color opacity to 0
Add script to load Lottie animation in the slide On Load event
// load Lottie animation into 'lottie' shape
var jsonAnim = {}; // replace {} by your JSON animation data
var animAPObject = prez.object('lottie'); // update the shape name
prez.loadLottieAnimation(function() {
var animLottieObject = bodymovin.loadAnimation({
container: animAPObject.node,
renderer: 'svg',
loop: false,
autoplay: false,
animationData: jsonAnim // or path: path to JSON file
// play animation on rollover/ rollout
var direction = 1;
animAPObject.on('ap-rollover', function() {
animLottieObject.setDirection(direction);
animLottieObject.play();
animAPObject.on('ap-rollout', function() {
animLottieObject.setDirection(-direction);
