prez.variable(‘slideIndex’, prez.currentSlideIndex());
if (prez.variable(“slideIndex”) == 1) {
prez.object(‘page_01’).fillSolid(prez.variable(“pagination_color”));
works fine the first time the slide is displayed but if I navigate through the other slides and come back, it’s not working until I reload the browser window. If I add ?slide=1 to url it’s working.
When I am troubleshooting these sorts of things, I like to create what I simply call troubleshooting boxes. These are nothing more than shapes on the screen to display my variable values for me.
In this case, I might create a shape and place %pagination_color% as the text so that I can track what the project believes the value to be. When you return to the slide you can see what the value is and react accordingly.
This will allow me to know if my values are changing the way that I expect them to.
Create as many boxes for as many variables as you need. You can delete them as soon as you have figured it all out.
That’s what I do and I get the correct values, seems to be an issue with view slide load and button states. I’ll try another approach with states, but I’m not sure yet if works for a page numbering on slide template.
