Problem: Me. I am use to actionscript not javascript (although learned a lot reading here about the Javascript API in Saola)
Saola Animate version: 2.71
OS: Windows 10
Notes: I want to be able to move an element with a button by code (using += etc.). I have learned about the timeline and triggers (an option).
setPosition works great, but only once. I wanted to use a variable to get the current x and y then add to it each time button is clicked etc.
You can get an element position from the dom object associated with the element. For example:
var element = doc.getElement('element name');
var elementDom = element.dom;
var elementLeft = elementDom.offsetLeft;
var elementTop = elementDom.offsetTop;
// set new position
elementLeft += 10;
elementTop += 10;
element.setPosition(elementLeft, elementTop);
You can also save the position to reuse without getting from the dom object. For example:
Thank you! I took a break from when I first purchased this software. I now have more time and have been learning how to use it and I continue to be SO IMPRESSED with it. Not too mention the amazing support. Means a lot to me.
