Problem: Cannot open the last slide pools when exeding 101 slide pools in a project
ActivePresenter version: ActivePresenter Pro Edition
Versão 10.0.0 - 64-bit. (Liberada: 2025.08.29)
OS: Windows 11 Enterprise
Notes: I have a project with 106 slide pools. All of the pools show up at the slide pane, and when I rum HTML preview the random slides appear correctly. The problem is when I try to see or edit slides contained in the pools.
When I select one of the first 101 slide pools I can see als the slides of the pool, but I cannot access none of the last 5 slide pools.
Is this a limitation i have to live with, or ist this a bug?
