Problem: I have created a few quiz interactions. It’s really cool to work with the program, but there are two problems.
First:
If the quiz is converted to html5, and I would like to try it in our LMS on an iPhone (in landscape), then the output is really tiny. I need to turn the phone to get it bigger. On my android phone, it is big immediately.
Second:
When I try to zoom in on my iPhone, the html5 is breaking down. I have no Idea why this is happening.
Thank you for your help in advance, and sorry for my bad english.
Regarding the tiny output, maybe due to your LMS.
On your LMS, is there any option that allows open the scorm with a new window/tab? If yes, please select this option and try again to see if it fits the screen or not.
When zooming in, maybe you misstouch any button, so it loads another page.
I think it’s not a problem of our LMS. Just to make it clear again. The problem is only on iPhones, not on Windows, android phones or an MacBook. I have the idea that it might be a problem with the “autoplay” from the iphone, because after the “break down” of the HTML5 the course starts from the beginning and if you return to the HTML5, it’s not small anymore.
In our LMS there is no option for a new window, but at the moment we are not working with scorm. Maybe in the future we will, but right now we create content like videos, slides in our LMS, and we work with the HTML files.
I have checked your zooming idea, but I do not touch anything before the page breaks down and the whole course starts from the beginning.
By the way…I have one template where it works completely fine. There is no breakdown and the output is in the normal size. But I can’t find the mistake or difference to the other templates to far…
