Hi, I have some text captions where i added audio using the TTS capability. However, I dont see the interactivity control for the audio. Specifically, I am looking for the “On Ended” capability that is available if i add the audio separately. It would be difficult to go back and separate out the audio files. Can you help?
Hi Ame,
For your information, the attached audio will play automatically when the object it is attached to appears, it does not support the “On Ended” event like a separate audio object.
We suggest you find the audio in the Resources pane (View tab > Resources pane) then drag and drop it into the Canvas. After that, you can remove the attached audio from the object.
Best regards,
