Problem: When I record an Interactive Simulation in a Hyper-V Virtual Machine nothing gets recorded. Most of the interactive simulations I need to make will be in different operating systems from my Windows 11 machine, so a VM is the only way to create them. Is there a workaround?
ActivePresenter version: 9
OS: Win 11
Notes: I’m trying to simulate the installation of a feature in Server 2008 on Hyper-V
Please run ActivePresenter as an administrator to see if it helps. Be aware that running ActivePresenter from an external source will not capture object information in Hyper-V. For instance, clicking a button may be displayed as “click here”.
If you want this information to be obtained, you need to install ActivePresenter internally. Additionally, please note that Windows Server is not officially supported; therefore, we are not responsible for any errors that might occur.
