It’s great that you can place a question placeholder.
But it would be even better to place a placeholder for a specific type of question. Eg. Multiple Choice
You can save your questions or specific question types as object template items then reuse them later.
To get it done, in your current project > click Save or Save As > select ActivePresenter Object Template (*.apobject) from the Save as type list > click Save.
Please make sure to save your file in the ActivePresenter Templates folder so that it can appear in the Object Template pane.
Check out this tutorial for more information:
Best regards,
