Importing PowerPoint
Am I the only person having problems importing PowerPoint presentations into 10.6:
  • Imports with bounding boxes (lines) around each item… including text
  • Messes with all formatting
  • It takes just as long to rewrite it completely, as opposed to correcting everything.
Am I doing anything wrong, or is it just not good at importing PowerPoint?
Any help or advice would be greatly appreciated.
I’m using a MacBook Pro if that helps
Sorry to hear that you’re having trouble importing your PowerPoint presentation.
Could you please send us the PowerPoint file so we can investigate the issue? A screenshot or short video showing the imported result would also be very helpful.
Thank you.
Hi Kevin,
Thank you for sending us the PowerPoint file.
We’re glad to let you know that the import issue you reported has been fixed in ActivePresenter 10.6.2. Please update to the latest version, import your PowerPoint file again, and let us know if the issue persists.
Thank you for your help in identifying and resolving this issue.
Best regards,
Hoa
Thank you very much, I’m extremely grateful.
