Importing powerpoint - bullets
I’ve tried everything, spent over a day trying to figure this one out.
I’ve imported a large PowerPoint slide deck and modified it too much to turn around and start again.
Before importing it I stripped out all formatting, as previously suggested, which on the whole worked fine, but now when I try to add a bullet point, it inserts an indent but puts the bullet underneath the text and won’t allow me to modify it. I’ve gone down the rabbit hole of Ai, which none of it worked and I simply went round in circles for hours.
I’ve used the old-school fix of using Fn+8 (on Mac), which works well, until my text strays into more than one line, it won’t justify the 2nd line… which looks horrific.
Can anyone offer any help or guidance. In PowerPoint I’d simply use the ‘ruler’ option and move the sliders to justify the 2nd line, but unfortunately, ActivePresenter doesn’t have that feature.
I really don’t want to start again with this massive project, but I can’t leave it as it is, it looks terrible.
Many thanks in advance.
Hi Kevin1,
Thanks for the detailed description, and sorry for the trouble you’re having with the bullets.
Could you send us the files below, so we can take a closer look?
  • The PowerPoint file and the ActivePresenter project after importing it. Just keep the slide with the issue and delete the rest.
  • A few screenshots or a short video showing what happens when you add the bullets.
You can send them to support@atomisystems.com.
Thanh
