- Is at least Powerpoint 2016 and its morph transition supported?
For PowerPoint Exporting on Windows, you’ll need PowerPoint 2016 or later, as mentioned in the system requirements here: ActivePresenter - System Requirements or on page 25 of the Manual.
About the morph transition, it’s currently not supported in version 9. We’ll consider adding it if there are more requests from users.
