Is there a reference for learning JavaScript syntax in ActivePresenter?
Examples include commands such as prez. and ap. Makes the syntax different from generic JavaScript
In the user manual, there is a great reference to get started.
Starting at page 320 there is a great deal of documentation.
You can find it under the help tab.
@aaid555 - I created a resource that you can use in conjunction with the user manual.
Both resources together should help provide lots of ideas for how to get JavaScript working in your projects.
Hopefully this is helpful to you in some way.
