Problem: Am I able to add a hyperlink or open a PDF (which is saved as a resource), not published on the web? EG user clicks link/box then PDF opens
ActivePresenter Version: 7
OS: Windows
OS: Windows
Hi Noma,
To add a hyperlink, please select the text, then open the Home tab and click the Insert Hyperlink button:
When the Insert/ Edit Hyperlink dialog apppears, select Resource (1) > Select a PDF file from your project (2) or from your computer (3) > click OK:
THANK YOU!!!
