Problem: I am a newbie on this software and I am using this to create a tutorial video. From the video I am working on, the fram rate is about 30FPS only, how can i set it up to 60FPS? Please help
ActivePresenter version:
OS:
OS:
Hi Tuấn,
You can change the default frame rate to 60 fps when exporting your project to video (Export tab > Video) as in the image below:
If you want to record screen at 60 fps, please set up the recording settings as follows:
Open the Recording dialog by clicking the Settings (gear) icon at the top-right corner, then select Recording Settings… from the pop-up menu.
When this dialog appears, you change the frame rate to 60, select H.264/MPEG-4AVC from the Video Codec list, and select Use Direct3D for recording screen.
Note that it partly depends on your computer to record screen at 60 fps.
Hang
