I have a retake quiz button i set it to take the students to the first question but when that happens they can’t reanswer because its already answered
ActivePresenter Version: 7.5.9
OS: Windows 7 64-bit
There are two methods:
make perfect sense… thank you
how can I restart a quiz if it is only a part of a larger presentation. So, restarting the presentation is no option here.
Hi Augustin,
You can increase the quiz Max Attempts as I mentioned above, and add action to go back to the slide with the quiz to answer it again.
You may aslo add action Clear User Input to the quiz slide On Load event to clear the previous answer if you want.
Hello,
I have the same problem and did exactly what you 've mentioned, but it doesn’t clear users input when someone tries to do the test again. The test is with the Fill in Text Entry. Can you please help? Thank you
Good morning @Fotini,
Please try doing the following steps:
Hope it helps you.
BR,
It helped a lot, thanks!
