Hi. I am using AP to create some videoclasses. I have made some “jumpt cuts” along a slide. The vertical red lines are there, along the timeline, showing the cuts were made. But how can I restore just one of them to the original? I try to select one of the red lines but it does not work.
Unfortunately, it is impossible to “erase” the cut point directly on the video.
However, you can select the Undo button or Ctrl + Z to undo the last operations. Or you can select View > Resources and find the original video file in the Video tab of the Resources pane.
