New user here-- how do you resize the slide when you start any new project? Thanks.
You can change the slide size of opening project by going to the Design tab > Slide Size.
If you want to set the default project size when starting any new project, just access the ActivePresenter button > Preferences > General tab > Default Project Size.
For more information about changing project size, you can refer to this tutorial:
