Problem: I know how to copy a range, but I don’t know how to paste the copy into another location. I’ve tried positioning the pointer somewhere and doing CTRL-V, but that seems to muck things up.
ActivePresenter Version: 7.3.2
OS: Win 10
OS: Win 10
A copied range will be pasted as new objects instead of joining with existing objects.
In case of audio/video objects, you can use Join Audio/Video Objects tool to merge them together after pasting.
Thanks toanis, I’ll start studying up on Join Audio/Video Objects
