Problem: How can I insert an object I imported on project library in the timeline? I can change or swap an object already in the timeline, but I cannot find how to insert one already in the library.
It seems that you are mentioning the Resources pane. You can click the View tab, select Resources to open this pane. Then, you can import all necessary resources in this pane.
To insert any resource from this pane into the Canvas, you just need to drag it or right-click a resource > Insert to Slide.
