How to remove / hide this horizontal bar?
Hi Fabio,
That’s the Results bar in the question Review mode.
To hide or remove it, please navigate to the question slide Properties pane > Interactivity tab > Events - Actions section > On Load event > Show responses: All showing interactions action > uncheck the Results option.
For more information kindly refer to this tutorial:
Please share your project so we can further check, Fabio.
You can attach it here or send it to support@atomisystems.com.
Thanks for sending your project, we received it.
Please customize the Show Responses action of your Termina button.
Deselecting the Results checkbox helps you resolve the issue.
Great!
Many thanks
