Hello! I am trying to figure out if there’s any way that I can do a project and get iFrame or HTML code so I can embed it somewhere else?
You do have the ability to publish as HTML5 with the Pro Version.
As for iFrame - you would need to make the published HTML5 project reachable from the other project where it would be iFramed in.
ActivePresenter will not provide any embed codes for you as far as I know. You would need to do that on your own.
You could check out this link for some good information on it.
