I have two slides and the cursor path ends on position A on the first slide. I want to begin the cursor path on a different position (B) on the second slide. When I move the A coordinates, the B position copies the movement. I want to break this connection.
There´s a workaround - add the copy of the slide between (set the duration to zero) and remove the cursor path there, but the screen flickers and it´s very cumbersome. Is there any better solution?
ActivePresenter version:
Version 8.3.2
OS:
Windows 10, 64bit
