Dear ActivePresenter Support Team,
I have a question regarding text selection behavior in ActivePresenter.
In my project, I would like to disable text selection for all text objects across all slides. I know that for individual text captions or shapes, I can uncheck the “Allow Text Selection” option in the Size & Properties tab. However, doing this manually for every text object in a large project is quite time-consuming.
Is there a way to disable text selection globally, for all text objects throughout the project?
I’d appreciate any guidance or best practices you can suggest on this.
Best regards,
