How to disable keybord shortcut cancelling recording alt + c?
Hello, how to disable keybord shortcut cancelling recording alt + c?
You can take a look at:
Scroll down to the section “Customize Hotkeys for Recording Projects”.
You cannot disable this hotkey. There is also no search option, and when expanding the pluses, the scroll flies up all the time.
This is very annoying.
In Polish, under “alt + c” we have the letter “ć”. Every time I write something, the recording turns off.
Found it.
I have created the account here only to thank you for this post. :folded_hands:
