I want to create a page/form that students can answer questions and draw items then submit the content to their Grades in CANVAS LMS so teachers can have proof of completion.
ActivePresenter focuses on helping you design eLearning content. Once your content is ready, you can export it as SCORM or xAPI packages, which are compatible with most LMS platforms that support these standards.
Drawing items is currently not supported in ActivePresenter. However, you can use web object to embed a drawing application into ActivePresenter:
Or, refer to this workaround that supports line drawing: Draw on html5 output slides - #12 by phuongdv
For more detailed instructions, you can refer to the Canvas Instructor Guide which provides step-by-step tutorials on creating assignments and quizzes
(How do I create an online assignment? - Instructure Community - 950)
Thanks for your answer but I am “not” looking to create an assignment. What I want to do is to insert in the content page an “Object/Tool” that would allow the input of the student and once completed to pass the results to the Grades. The input could be either text or a way to draw.
It could be something like this tool that we are using to communicate:
Thanks for your information.
This cannot be submitted to the LMS, even if using script to draw. The reason is that SCORM and xAPI standards do not support interactions that involve submitting images or files.
