I would like to add videos and pictures to Active presenter 7 library not to project library to be accessed to all my projects
ActivePresenter Version:
7
OS:
Windows 10
7
OS:
Windows 10
Can you please tell why you want to add to ActivePresenter library instead of storing in a folder on your hard disk? Anyway, you can use the Object Template feature as an alternative way for this. You can find more information at https://atomisystems.com/tutorials/ap7/creating-using-object-templates/
Adding pictures and videos to active presenter’s resource library instead of repeatedly adding them to every project saves a lot of time and effort
This option was available in version 6
Nabil
Thanks for your information. This feature has been removed since version 7. You can use Object Template for the same purpose.
