Problem: How to add code into HTML tags?
Saola Animate version: v3.0.1
OS: win10
As the page Use External JavaScript, CSS, and HTML in Saola Animate 3 teach us to insert external JavaScript into Saola.
If an external JavaScript library need to add some code to work, for example,
<html><head> need some style settings here </style> </head>
<html><body> need some script tags and code here </body></html>
Q) how can I add code into tags above?
or it is impossible, so I should modify HTML5 after export them from Saola.
Thank you very much,
Afei
