How do you add Timeline Actions to Top Layer objects?
(1) I’m trying to add the following Timeline actions to an object in the Top Layer, but the timelines are not appearing for me to select them. Am I preventing it from appearing somehow?
On Click > Continue Timeline
On Click > Pause Timeline
On Click > Start Timeline
(2) Also how can I do this using the Execute JavaScript action?
the following works for me:
//Pause Timeline 1
prez.pauseTimeline('Timeline 1');
//Start Timeline 1
prez.startTimeline('Timeline 1');
But how do I add the Continue Timeline action? The following JavaScript doesn’t work for me:
prez.continueTimeline('Timeline 1');
ActivePresenter version: 9.3.0
OS: Windows 11
Please see the answers below:
1.Timeline Actions Not Appearing
Timeline actions like Continue, Pause, and Start are not available for objects that display over multiple slides. These actions only work for objects that exist on a single slide.
2. JavaScript to Continue Timeline
To resume a paused timeline via JavaScript, please use:
prez.pauseTimeline('Timeline 1', false);
This acts like a Continue Timeline action.
Hope this helps!
Thank you Hang this helps a lot!:slightly_smiling_face:
Can I just check that applying the following JavaScript code to an object in the Top Layer won’t break my slides somehow? I want to be able to click a top layer object to affect multiple timelines across multiple slides:
On Click > Execute JavaScript (Play Timelines)
// Array of timeline names
const timelineNames = ['Timeline 1', 'Timeline 2', 'Timeline 3’];
// Loop through each timeline name and play it
timelineNames.forEach(timeline => { prez.pauseTimeline(timeline, false); });
On Click > Execute JavaScript (Pause Timelines)
// Loop through each timeline name and pause it
timelineNames.forEach(timeline => { prez.pauseTimeline(timeline); });
On Click > Execute JavaScript (Start Timelines)
// Loop through each timeline name and start it
timelineNames.forEach(timeline => { prez.startTimeline(timeline); });
Thanks for your response.
Unfortunately, it’s not possible to use a Top Layer object to control timelines across multiple slides. JavaScript only works within the current slide’s context.
