When I add a new slide, I’d like to have its default duration to be 50 seconds. I was able to do this in the earlier version, but I can’t figure out how to do it in the current version.
The problem is that I’m doing voice-over narration with the slides. Is there a way to either a) set the default duration of a slide to 50 seconds, or better yet b) have the duration automatically increase with the recording? (Currently the recording stops when it reaches the end of the slide duration)
Unfortunately, there is no way to set default slide duration in ActivePresenter 7.2.3. We will improve this in the next release, it will be available in next few days. In the next release, the slide duration will get from its layout in slide master.
In the meantime, if you have to insert many slides, you should insert some empty slides first, then select all slides and set the slide duration to reduce the editing time.
About the question b), this function is not available in ActivePresenter.
