How do I join all the Audio Visual components into one object?
I’m new to Active Presenter 9. How do I join the System Audio, Audio, and Video objects into one video object on the editing timeline. I’m not merging multiple videos into one video, I’m combining–what appear to be separate—components of one video into one video that I can edit. So I have this:
And I’m trying to get to this:
Unfortunately, ActivePresenter doesn’t offer a direct way to merge video and audio into a single track in the Timeline pane. However, as a workaround, you can export the slide (or the entire project) to video, and then re-import that video back into ActivePresenter.
For more guidance on getting started with ActivePresenter, please refer to our Tutorials page: ActivePresenter 9 Tutorials - Atomi Systems, Inc.
Sounds good. I understand. As I work with this more, I realize it is more like a slideshow, so I’ll do better to design my projects along that line.
