Hotspot question problem in Firefox
Problem: When trying to mark a place on the image, the hotspot appears outside the mouse click (cursor) location. This error distance varies depending on the size of the browser window. In Chromium-based browsers, hotspots works normally. Questions created in ActivePresenter 8 did not suffer from this ailment. I see the problem in current and older versions of Firefox.
ActivePresenter version: 9
OS: Win10
Please share your project with our support email address support@atomisystems.com or attach it here so we can check.
BR,
Thank you for fast reply! I sent the project on support email.
Tomas
We’ve received your email, @_MTF. Thank you for sending the project.
It looks like there’s a bug with the Firefox browser. We’ll investigate it and work on a fix in the next updates.
We apologize for any inconvenience this might have caused.
BR,
Thank you very much!
Tomas
Hi @_MTF,
This issue has been addressed in ActivePresenter’s latest release, version 9.2.0.
Please go to the Help tab > Check Updates.
BR,
