In this project you will find a card game where you must determine if the next card is higher or lower than the first one.
Features of this project:
Randomized card draw using a single deck of cards
Round tracking
Money tracking
Ability to set your bet
Money formatting should be based on your location. (This is untested in other countries right now. It functions OK in the USA with comma as a separator - I tried to accommodate for decimals as well as the half-space but do not have a way to reliably test. Let me know so I can try to fix. Unsure if other separators will cause the game to break or not.)
