rzjunction
(Roger Zimmerman)
1
Problem: I have my own numbering system. How can I hide the slide numbers in the table of contents?
ActivePresenter version: 9
OS: Win 11
Notes: In the image, the number to the left (slide numbers) confuse the reader with an extra unneeded number.
Hi Roger,
You can hide the slide numbers in the table of contents with some simple steps. Here’s how:
- Access the Export tab > Player Settings > Table of Contents tab (1)
- Click the Settings icon (2) > Select None in the Table of Contents Settings dialog that pops up (3) > Click OK (4) to save the change.
Hope it helps.
