Hello all! I have been using ActivePresenter for simple interactions but want to move into more use of variables and advance actions. I want to start with what I hope is a simple step: I have a few text entry boxes on an image that students need to type into to label parts of the image. There is also a continue button to go to the next slide. I would like to make the following action:
I want the Continue button to be hidden initially. Then, I want the user to type in a box, hit enter and get the feedback until they get the correct answer. I would like the user to do this for all of the text entry boxes on the slide. Once all boxes are correct, I would like the Continue button to show.
Any suggestions on how I can do this? Iād really appreciate any ideasā¦thanks!
I might approach this problem by creating a variable to track the number of correct answers.
Letās say we call the variable numCorrect
Then with all your text entry boxes - when they get the right answer - add 1 to the numCorrect variable.
Since we do not know the order in which the student will answer the questions - I would also have every correct answer submission check the value of the variable.
If the value of the variable is equal to the number of text entry blanks, it means they submitted all the answers correctly so we show the continue button.
Hopefully I was clear with the idea and that it helps you move forward.
Hi @gregs - thank you so so much for that! I think I understand what you mean. I created the variable and then for the āOn Correctā event for that text box I added the following condition:
Does this look right? If not, please let me know, but if so and I then do it to all of the text entry boxes on the slide, how do I get the Continue button to appear?
At the moment, I have it set to āInitially Hiddenāā¦does that sound right? Iām thinking that I need to create some kind of advanced action that will show the Continue button but Iām not quite sure how to do that. Iām kind of just crossing the bridge from Adobe Captivate to ActivePresenter so itās a bit confusing from here. Could I ask you for a bit more guidance on showing the Continue button?
Thank you so much @gregs - I will try that and see if I can follow your lead. Iāll keep you posted. Thanks again for your help!
PS: Captivate is great but we wonāt be switching to the new one at work and this is more user friendly for most of the people we are working with; I have to learn more first to train others lol!
It worked! Thank you so much @gregs - Iām so pleased with how straight forward and easy it was. Thanks againā¦Iām sure Iāll be back for plenty more as the weeks wear on, but this also gives me lots of ideas for playing around
