Some of the slides I have created have a lot of objects in them and the bottom panel becomes rather cluttered. It would be nice to have a way to group objects in the bottom pane together and collapse or hide them so that just the objects I’m working on are visible.
Hi Paul,
The bottom pane is the Timeline. You can place multiple objects which are displayed sequentially in a line in Timeline to reduce vertical space they take up. To move an object to an existing line, you just need to select the object, drag and drop it to the appropriate time in the line.
Regards.
