Hidden Resources
I may have missed it, but is there a way to hide resources and/or embedded fonts when publishing to HTML5?
Thank you.
Hi Roxie,
Do you mean you want to hide the Resources button in the HTML5 output?
Please take a look at this tutorial if removing the button is what you want.
If not, kindly clarify further so I can understand what resources you want to hide.
About the embedded fonts, when exporting your project to HTML5, in the Export to HTML5 dialog, check or uncheck the Embed Fonts option depending on your need.
Let me know if the information helps.
BR,
Quynh Anh
Thank you for your quick response. No, I’m referring to the resources from the exported project, such as images and other media, as well as the embedded fonts. If the project is published to a public site, could these sources be published in such a way as to not be attainable by others?
Thanks for your clarification.
In this case, unfortunately, there is no way to do that.
Let me know if you need any other assistance.
BR,
Quynh Anh
