If I group two objects, I select the two objects, right click and select group, it groups the objects.
However, if I go to Edit: Group, it is greyed out.
Does anyone else have the same issue?
I have Saola Animate 3.1.3 and Mac Ventura 13.0.1
Thank you for taking the time to report the issue you encountered.
Our development team will fix it in the next updates.
And we’ll let you know when the issue has been resolved.
In the meantime, to group elements in Saola Animate, you can do either of the following:
Have a good time,
