Usually (in HTML) when you have a group of radio buttons, checking one radio button should uncheck the rest of them.
But in ActivePresenter, when I add multiple radio buttons to a slide all of the radios are disconnected from each other. I can check each radio individually, and it will remain checked when checking any of the other radios… which kind of defeats the purpose of radio buttons.
I can see no way to group radio buttons at all. I have tried giving all of the radios the same name (which is how they group together in HTML) but that didn’t work.
Is there something I am missing? Or does ActivePresenter not support the grouping of radio buttons?
Thanks for any advice you can give!
ActivePresenter version:
9.2.1
OS:
Windows 10
