Grouping Elements
  1. I am trying to group all my symbols (1-10) and backgroundAnimation Layers. It shows it is grouped under the properties panel. However, in the timeline it does not show them under the group folder. Am I missing something?
  2. When I drag my Happy Halloween image on the scene, it is visible. However I do not see it on my timeline.
Attached is my file.
I would appreciate any suggestions.
Saola Animate version: 3.1.3
OS: MacOS Ventura 13.0.1
halloween.zip (470.1 KB)
Hi @user2651
Thanks for attaching the project to help us know exactly your issue.
Please click on the Show Animated Elements Only button placing under the Canvas.
Then, you’ll see your Happy Halloween image and the group elements is shown on the Timeline pane.
Hi @PhuongThuy_Le
Thank you for your help, I really appreciate it.
