I need to set up 3 pools of questions, connected to a report slide where the result is shown separately. I’ve tried to use the default variables, but they only work for the total quizzes taken in the project.
I’m sorry but I’m not sure what did you mean. You don’t know how to add a variable, or you want to show the percentage instead of the “correct / total” (e.g show 50% for 5/10 correct questions)?
Sorry, I should have made my question more specific. I’m trying to set up the variable “apQuizTakenInteractions” but for each group of questions, not for all the project. Ideally, I’d like to show the result as a percentage instead of a complete number. So that the user can see the progress of completion.
eg. Group 1=
Correct Answers: %group1Corrects% / 12
Answers complete: 50% (in this case the user completed half of the questions, no matter correct or incorrect.)
I hope there is a way of doing that, if not, I’ll adapt the content.
To count the number of complete questions, you just need to update the variable in both On Correct and On Incorrect events for graded questions and On Complete event for survey questions, as shown in the following screenshot:
Showing the number of complete questions in percentage is quite complicated because it’s real number, not integer. We need to use JavaScript to handle some more things such as the rounding error, the display format (e.g. show how many digits after the decimal point)… So I think you should display it as %group1Taken% / 12 instead of percentage.
You can set the question max attempts to infinite so that they aren’t disabled once answered. Because the max attempts is not 1, the user can answers a question multiple times, so we must add an additional variable for each question to mark it as complete or not and update actions to count number of complete questions.
For more details, please see the revised project. RestartButton.revised.approj (864 KB)
