Problem: Ghosting of objects from previous slide on video export
ActivePresenter version: 9.1.3
OS: Windows
I’ve imported a set of powerpoint slides that I am turning into a video. One one slide, I have a number of objects including several boxes with no line, but custom shadows imported from PowerPoint. The next slide starts blank with a voice object introducing the slide.
Until the first new object is shown, there are “ghost” objects from the previous slide - the shadows of the boxes. I’ve confirmed this by changing the shadow colour and this is visible.
The shadow is on the next slide - confirmed because the voice over on that slide has started. If I change an object so that it has a line, but no shadow then the ghosting does not happen.
Similarly, if I change the shadow to one of the ActivePresenter presets, the ghosting goes away.
I’ve just changed the object, sorts my issues out and fixes the video - but seems like a bug in the powerpoint import?
