Hello, I added 2 buttons to make full screen and real size in my project. When I press the full screen button, the screen gets bigger, but when I press the “esc” key, the screen shrinks without changing the icon. How can I get the “esc” key to be checked?
Hi Emrah,
You can handle the fullscreenchange
event in the project On Load event to update the icon:
AP.fullscreen.addEventListener('fullscreenchange', function() {
if (AP.fullscreen.fullscreenElement()) {
// fullscreen mode
} else {
// normal mode
Thanks it worked. But it works once because it is added to the onload part. How can I make this permanent? (It worked with the first click, then it didn’t work when I clicked again. The screen gets smaller, but the button icon does not change) @ToanLS
The fullscreenchange
will occur everytime the fullscreen mode is changed, so it should always work, not just once.
You can send your sample project to support@atomisystems.com for checking if you can’t manage to make it work.
Hi Emrah,
Thank you for sending the project via email. We will check it and respond to you promptly.
Best regards,
Thank you, I look forward to hearing from you.
Hi Emrah,
Your project use the tamekran
variable to update the fullscreen icon when changing slides, so you’ll need to update this variable in the fullscreenchange
too.
// fullscreen mode
prez.object('tamekran').hide();
prez.object('tamekrançık').show();
prez.variable('tamekran', true);
} else {
// normal mode
prez.object('tamekran').show();
prez.object('tamekrançık').hide();
prez.variable('tamekran', false);
You can also make tamekran
and tamekrançık
show over multiple slides so that you don’t need to update them on each slide.
