Fonts no longer exporting in preview
Hey,
I updated ActivePresenter 10 with the last release (10.1.1) and when I launch a preview of my project, the fonts are non longer exported. However, they are exported just fine when I export my project in HTML, but it makes my tests so much longer.
Do you know about this bug ? Have you plan to fix it ?
Thank you !
Bonjour, Camille -
I have also noticed this in version 9 with some projects where a few parts will render properly and others do not.
As you say - all is well with the final publish.
Honestly - I have not worried about it too much myself as the final project is good but I agree that it would be much nicer to see all the text rendered in the designated font for previews prior to publish.
Hi Camille and Greg,
Thanks for sharing your observations.
This behavior is actually not a bug. In Preview mode, most fonts display correctly because they are based on the fonts installed on the user’s computer. However, some specific or non-standard font names may not render properly in Preview.
We understand how this can affect the testing workflow, and we’ll consider improving this to provide a better user experience in the future.
Thank you for your answer.
It’s weird because it didn’t do that before the update, the project is the same, so are the fonts and they are installed on my computer. The only change as for me is the update of the software.
__
Camille
