Font compatibility issue on different browser
Hi, I am currently facing an issue regarding the font compatibility issue across different browsers. I had tested my SCORM package across a few different browser.
and Yes this happened with embedded font option turned on. How do I go about this issue? Thanks for the help!
Hi @Aizuddin_Amin,
First, I just want to let you know that we do not officially support the Brave browser.
As we need more particular information to find out the cause of the issue, could you please share us the project including the issue and its external data folder named in the PROJECT_FILE_files (if any) to support@atomisystems.com so that we can check.
If these files are large, you can upload them to a cloud storage site like Google Drive then send the download link to us.
Please take note to open the access right to the link as well.
And, let us know the font you are using in this project.
You can directly send us the font via the mail as well.
Looking forward to your update there.
BR,
Quynh Anh
Hi, I’ve contacted the support team with the files requested, after trying the SCORM package on different devices running on chrome browser ( MacOs,Windows), I was not able to reproduce the problem. The problem only happened on animated timer font that are used in multiple slides.
