Question: Is there a way to have the Focus Indicator also display around the Player buttons when the user tabs to them?
ActivePresenter version: 8.3.2
OS: Win 10
OS: Win 10
Hi Keith,
The focus indicator for player buttons is already enabled but it is not quite clear.
You can change this by opening the file at C:\Program Files\ATOMI\ActivePresenter\templates\html5\css\rlplayer.css with a plain text editor (like Notepad), then search for the following lines:
.ap-button:focus {
outline: #808080 dotted 1px;
and change to your desired effect, for example:
.ap-button:focus {
outline: red dotted 2px;
Finally, save the file and export your projects again.
Hi Phuong,
I had to boost it to 4px so that it was more visible, but it works great.
Thanks!
Keith
